Electric potential and free fall acceleration problem
On planet Tehar, a 4.05 kg ball with a charge of 4.65 μC is thrown upward and impacted by both gravity and a downward electric field. The trajectory analysis involves calculating the height reached using average velocity and time, resulting in a height of approximately 10.323 meters. The potential difference is derived from the conservation of energy equation, leading to an initial calculation of 1.26 x 10^8 volts. However, the final answer must be converted to kilovolts, resulting in 1.26 x 10^4 kV. Clarification on the approach and conversion process is sought due to confusion regarding the calculations.
Punchlinegirl
On planet Tehar, the free fall acceleration is the same as that of Earth, but there is also a strong downward electric field that is uniform close to the planet's surface. A 4.05 kg ball having a charge of 4.65 \mu C is thrown upward at a speed of 22.2 m/s, and it hits the ground after an interval of 1.86 s. What is the potential difference between the starting point and the top point of the trajectory? Answer in units of kV.
First I drew a free body diagram and found that the only forces on the ball were the force of the charge and gravity.
So qE + mg = ma
where a is constant.
Then I figured out the height of the ball by adding the final and initial velocities and dividing by 2 and multiplying by the time/2.
22.0+ 0 /2 *1.86/2
h= 10.323
Then I used conservation of energy
KE_o + PE_0 +EPE_o = KE_f + PE_f + EPE_f
1/2mv^2_o +0 +0 = 1/2 mv^2_f + mgh +qV
So V= 1/q ((1/2)mv^2_0 -mgh)
V= 1/4.65 x 10^-6 ((1/2)4.05(22.2^2) - 4.05 (9.8)( 10.323))
V=1.26x 10^8
V= 1.26 x 10^4 kV
This isn't right.. can someone tell me what's wrong?
Well what I did is first calculated the gravitational acceleration of the planet from the data. That enables you to calculate the electric field strength from your first equation. That with the height gave me
V=Ed=1.26 \times 10^8\ V
I got that, but the answer is supposed to be in kV. So that would make it 1.26 x 10^4, right?
Is this the right approach or am I doing it completely wrong?
Sorry I do not understand the system, since sometimes it notifies me via e-mail when someone posted in the thread, but it did not do it in this case. kilo is 10^3 therefore 10^5 will be left after taking away 3 from 8.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
