The Amount of Energy released by a tropical thunderstorm
The discussion focuses on the relationship between precipitation and energy in tropical thunderstorms, emphasizing the latent heat released during condensation. It highlights that the mass of water in a storm is 9.72 * 10^8 kg and involves calculations based on the storm's air intake and condensed water volume. The latent heat of vaporization is specified as 2.5 * 10^6 J/kg, which is crucial for determining the total energy output. Participants are encouraged to calculate the total Joules of energy generated by the storm using these parameters. Understanding this energy release is essential for comprehending thunderstorm dynamics.
button2
I can't quite figure this out... but given this sceneraio:
Precipitation and energy can be thought of as closely related quaniities in a thunderstorm. That is, when rain forms via condensation, the atmosphere warms from the latent heat released. The amount of heat energy must be proportional to the amount of rainfall produced. In this case, the mass of the water content in a given thunderstorm is 9.72 * 10^8 kg. If a storm ingests 2.16*10^9m^3 of air with 9.72*10^5m^3 as condensed water, and given that the latent heat of vaporization is 2.5*10^6J/kg, what is the total number of Joules of energy generated by this storm? :confused:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
