Calculate AC Circuit Power: Toaster 3A, 240V, 50Hz
  • Thread starter Thread starter frozen7
    Circuit
An electric toaster operates at 3A rms current and 240V, 50Hz, allowing for the calculation of average power using the formula P(average) = I(rms) x V(rms) cos φ. The power factor is not specified but is likely unnecessary for this calculation. Given that the toaster's heating element is purely resistive, the power factor can be assumed to be one. This means all energy is converted to heat without any phase shift between voltage and current. Thus, the average power can be calculated directly without needing to consider a power factor.
frozen7
An electric toaster draws 3A rms current from a 240V, 50Hz source. Calculate the average power and peak value of the instantaneous power to the toaster.
P(average) = I (rms) x V (rms) cos \phi
Since the power factor is not mentioned in the question. Can the question be solved?
If the power factor isn't given, it probably isn't needed. What would you guess the power factor of a toaster to be? What is the heating mechanism?
Is it because all the energy become heat so the power factor is equal to one ?
Yeah. The heating element is purely resistive, and the power factor of a resistive circuit is unity. You only get a phase shift between the applied voltage and resulting current if the load is reactive.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
