Parallel electric plate question
The discussion revolves around calculating the velocities of charged particles in electric fields created by parallel plates. For the alpha particle, the key steps involve determining the electric field and using energy conservation to find its velocity upon hitting the negative plate. The second scenario focuses on an electron's motion through a different set of plates, requiring similar calculations for electric field, force, and acceleration. Participants suggest breaking down the problem into manageable steps, emphasizing the importance of understanding the relationships between electric fields, forces, and kinetic energy. Overall, the conversation highlights the complexity of these physics problems and the need for systematic problem-solving approaches.
silvercyanide88
1. If an alpha particle (q=+2e, m = 6.64*10^-27kg) is released from the positive plate (Vab=120V and the distance separating the plates is 12cm), with what velocity will it hit the negative plate?
2. An electron is fired from a negative plate toward a hole in a positive plate. It then passes between two parallel plates that are 3cm long and 2cm apart with a voltage of 550Volts across them. If the accelerating voltage across the two original plates is 900 volts what is the final velocity of the eletron?
Ooooh my head spins. I haven't the slightest clue where to start. Could someone give me a hint?
-1- What is the magnitude of the electric field in that region? What is the equation for the force on a charged particle due to an E field? What equation relates force and acceleration. What equation relates acceleration and velocity?
-2- Draw the geometry, and draw the E field lines. Use the equations from -1-.
Quick Hint:q\Delta V =Change in Kinetic Energy
Okay, so I got the first one... but the 2nd one boggles my mind. Could you give me a more... obvious hint? I tried doing vectors but that confused me even more...
Using conservation of energy, you should be able to calculate the speed of the electron when it comes out of the original plates (this is the same as question 1).
Now let's pretend that the electron is moving along the x direction (with a v_x given by the speed you found just above) when it enters the second pair of plates (which are horizontally aligned so that the electric field between them is vertical).
the steps are:
a) figure out the E field between those two plates.
b) Figure out the electric force on the electron (which is a vertical force)
c) Find the vertical acceleration of the electron
d) using the velocity along the x direction, figure out how long it takes ti get across the plates
and then there is a last step that should be clear.
Patrick
Ah, yes. Thank you so much.
