Acceleration of object - how much time does it take
  • Thread starter Thread starter lumtesm
    Acceleration Time
To calculate the distance an object needs to reach 45 mph in 3.7 seconds, first determine the acceleration using the formula a = (v_f - v_i) / Δt. For 45 mph, which equals 66 ft/s, the acceleration is approximately 17.84 ft/s². Using the distance formula x = 0.5 * a * t², the distance required is about 122.1 feet. This calculation is relevant for racing go-karts and similar applications.
lumtesm
hey
does anyone know how to calcuate the distance it would take for an object to reach 45mph starting from 0mph with a time limit of 3.7 seconds?
its not a homework question, i acctually race go karts and was curious if there was a way to calculate that
thanks for your help
Mike
lumtesm said:
hey
Mike
EDIT OOPS! I was sure you had asked about the *acceleration*!
Once you have the acceleration, you may calculate the distance using
x_f = {1 \over 2} a_x t^2
Of course. The acceleration is simply {v_{x,f} - v_{x,i} \over \Delta t }.
You have to be careful with units. I am not sure what units people use quote acceleration of cars in the non-metric system, but it could be in mph/s (miles per hour per second) or miles per hour squared or miles per second squared. I have a hunch that the first would be the standard one (mph per second) in which case you would just divide 45 mph by 3.7 seconds. (In the metric system, it's of course given in m/s^2, meter per second squared).
Patrick
45 mph = 66 ft/s, use ft/s in the above formula.
Therefore, acc. = 66 ft/s / 3.7 s = 17.84 ft/s^2 = a.
So the distance, x, using the formula = 0.5 (17.84) (3.7)^2 = 122.1 feet.
