Find Maximum Elongation After Fracture in mm
To find the maximum elongation after fracture in millimeters, the same method used for measuring elongation applies. After a fracture, the elastic strain is mostly recovered when the load is removed. To measure elongation, align the fractured pieces and measure the length between marks of the original gauge length, then apply the elongation formula. This method provides the total permanent elongation, excluding the elastic component at failure. The elastic strain can be estimated as the yield strength divided by the Young's modulus.
teng125
how to find the maximum elongation after the fracture in mm??any formula??
pls help
thanx
One uses the same method/formula as elongation.
When a piece fractures, the load is removed, so the elastic strain is mostly recovered.
One puts the two broken parts together, matching the fracture surface, and measures the length between the marks of the original gage length. Then use the elongation formula. This however gives the total permanent elongation which does not include the elastic component at time of failure.
The elastic component of the strain (elongation) is approximately the yield strength divided by the elastic (Young's) modulus.
