How Strong is the Stopping Force for a 1.5×10^4 N Car?
  • Thread starter Thread starter bearhug
    Force Magnitude
To calculate the stopping force for a car weighing 1.5×10^4 N and moving at 45 km/h, the mass is determined to be approximately 1.53e3 kg. The correct method involves using the equation for acceleration, where acceleration can be derived from the initial and final velocities over the stopping distance. An alternative approach utilizes the kinetic energy formula, leading to the equation F = mv^2/2d for calculating the stopping force directly. The discussion emphasizes that both methods are valid, but the energy approach may be more straightforward. Understanding these calculations is essential for accurately determining the stopping force.
bearhug
A car that weighs 1.5×104 N is initially moving at a speed of 45 km/h when the brakes are applied and the car is brought to a stop in 12 m. Assuming that the force that stops the car is constant, find the magnitude of that force.
I found the mass to be 1.53e3 kg then I figured now I need to find the acceleration using the information that I have so I used the equation
Vf^2 = Vi^2 + 2a(Xf-Xi)
Vi = 12.5 m/s
Vf = 0 m/s
Xf = 12m
Xi= 0 m
Then plug the acceleration value into the equation F= ma but apparently that's wrong. Is this the correct method?
Vi = 12.5 m/s
Vf = 0 m/s
Xf = 12m
Xi= 0 m
Method is ok. a = \Delta v/\Delta t \text{ where } \Delta t = 2d/v_i Since final velocity is 0, you have: a = v^2/2d
You are in effect using energy: KE = F*d = \frac{1}{2}mv^2[/tex] which is a little more direct:<br /> <br /> F = mv^2/2d<br /> <br /> AM
