The Length of Pendulum Strings: Motion Effects
anantchowdhary
When a pendulum is moving
will the length of the string that the bob is attached to appear to be contracted?I have this doubt as the string is sometimes in direction of motion and at one point absolutely not in the direction of motion
Appear to be contracted from whom's point of view?
From an observer's point of view whoo is in an inertial frame.If he wants to calculate the time period of the pendulum,how will he measure the length as it changes from position to position
Please answer!:D
Please sum1 help me out here!
Each infinittesimal portion of the string is a linie segment which is moving perpendicular to its motion. According to SR the length of the string will remain unchanged.
Pete
I assume that the OP meant that the swinging pendulum was in a moving rocket (say) being observed from the earth.
That's the usual way. Another way is to to have a charged particle on a string at a fixed distance from a charged plate. But you're right, he was probaby speaking of in a grav-field or in a rocket shift.
Pete
No,i just meant to have an experiment of a pendulum,moving at a constant velocity relative to a frame.Now the string of the pendulum,once is perpendicular to the direction of motion,and when it is at its maxima,it has some component in the direction of velocity,so my question was,wouldnt this affect the length of the string?
Also the time period as viewed from another rest frame would be the
T = \gamma T_0?
where T is the time period as viewed by the rest frame and T_0 ,Tthe time period as viewed by the moving frame.
PLease help.I would really ,like to know whether the above reasoning is correct or not!
