Rotational Kinetic Energy of ride
The discussion focuses on calculating the rotational kinetic energy of a merry-go-round under constant tangential force. The initial attempt yielded an incorrect kinetic energy of approximately 43.5 J, due to misapplication of the forces and ignoring the constant acceleration over 3 seconds. The correct approach involves using torque and angular acceleration, leading to a final angular velocity of 2.49 rad/s. This results in a calculated kinetic energy of 280 J, aligning with the answer provided in the homework. The importance of correctly applying rotational dynamics principles is emphasized throughout the discussion.
mathmuncher
A horizontal 800.0 N merry-go-round with a radius
of 1.5 m is started from rest by a constant horizontal
force of 50.0 N applied tangentially to the merry-go-
round. Find the kinetic energy of the merry-go-round
after 3.0 s. Assume it is a solid cylinder.
KE = (1/2)(Iw^2)
Answer in the back is 280 J
My answer, however, turns out to be 40ish.
Here's how I did it:
I found moment of inertia I of combined objects (I treated the forces as objects here):
I = I_(mgr) + I_(object_at_edge)
I = (.5MR^2) + (MR^2)
I = (.5*80*1.5^2) + (5*1.5^2)
I = 101.25 kg.m^2
Then, I chose the 50 N constant force as the force that maintains circular motion, so
50 = (mv^2)/r
50 = ((I/r^2)*v^2)/r
50 = ((101.25/1.5^2)*v^2)/1.5
v^2 = 1.667
v = 1.29
Now, KE = (.5)(Iw^2)
= (.5)(101.25*(0.86)^2)
= 43.5 J
Haha, awfully messy.
note you have not used the fact that it is asking you what happen after 3.0s. it said a constant force is applied tangentially so can't equate 50 = mv^2/r either... my guess from the wording of the question is that the merry go round is under constant acceleration.. you should work out the angular acceleration and torque... \tau= I\alpha where, I, here is moment of inertial of object.
Why do you state "combined objects?"
The 50 N is applied tangentially.
Thanks for the help. I have made a fundamental error here and I should have known better. I have reached the solution by using the net torque identity, which equals to I*angular acceleration.
t=Ia
Then since t=Fd
Fd = Ia
(50)(1.5) = (.5*80*1.5^2)(a)
a = 0.83 rad/s^2
Since a = (w_f - w_i)/t
0.83 = w_f/3
w_f = 2.49
Now we can easily conclude KE_f:
KE_f = (.5)(90)(2.49)^2
= 280 J
