Solid state switch or MOSFET: Which is the better relay replacement?
Solid state relays (SSRs) provide superior isolation and can handle AC loads, unlike single MOSFETs or BJTs, which lack this capability. While a triac with a photodiode can mimic some SSR functions, it requires multiple components, including several transistors and an opto-coupler, complicating the design. The discussion emphasizes that SSRs are specifically designed for relay replacement, offering a more straightforward solution. In contrast, using a single transistor or MOSFET does not achieve the necessary isolation or functionality. Overall, SSRs are recommended for applications needing reliable relay replacements.
Jdo300
Hi, I've been hearing people talk about using solid state switches/relays as replacements for relays on boards and I was wondering if someone could explain to me the difference between a solid state relay and something like a MOSFET or transistor. Why not just use one of those?
Thanks,
Jason O
A true solid state relay is able to pass AC and offers very good isolation between the control signal and the actual switch. A single MOSFET or BJT cannot offer this.
but two back to back can.
Reread my post. This will not accomplish isolation.
what about a triac with a photodiode on the gate.
Yeah I suppose, I've never looked into it. The original argument was:
So I'm going to stick with that. A triac with a photodiode on the gate sounds a lot like a solid state relay which the OP was questioning the replacement of with a single transistor. A triac is basically 2 SCRs back to back. An SCR is basically 2 transistors arranged in a fashion so they latch on until current is interupted. To provide the isolation needed it takes an opto-coupler which is usually 2 devices, but usually the output is 2 transistors in darlington configuration. So, let's count up the devices. One triac consists of 4 transistors, 2 more transisors for the photo darlington pair, and an LED. That's 7 individual components. Quite a stretch from the OPs idea of a single part.
Thanks for the clarification on that guys.
