An object open on both ends? V/WL/F
  • Thread starter Thread starter tasha_michelle
The discussion focuses on calculating the wavelength of the lowest frequency for a 3.0 m organ pipe that is open at both ends, using a sound velocity of 331 m/s. The key formula involves the relationship between wavelength, frequency, and pipe length, specifically that the wavelength is twice the length of the pipe for the fundamental frequency. Participants are seeking clarification on their calculations, particularly how to derive the longest possible wavelength in the pipe. The conversation emphasizes understanding the fundamental frequency and its corresponding wavelength in a pipe configuration. Accurate application of the formulas is crucial for solving the problem effectively.
tasha_michelle
A 3.0 organ pipe is open at both ends. The velocity of sound is 331 m/s. What is the wavelength of the lowest frequency?
am i missing something...i need a lil help here!
wavelength=2L/n fn=V/wavelength(n)=n(V/2L)=nf1
n(331)/(2)(3.0) ?
