Electric Dipole Force between Ammonia and a Proton
The discussion revolves around calculating the electric force exerted by an ammonia molecule on a proton located 2.50 nm away. Using the dipole electric field equation, the force is calculated to be -4.60E-13 N, indicating an attractive interaction due to the negative sign. The ammonia molecule has a permanent dipole moment of 5.0 * 10^-30 Cm, and the proton's charge is 1.60E-19 C. The student correctly identifies the need to use the perpendicular dipole equation for this scenario. It's emphasized that the student should explain the physical significance of the negative force value.
Badger
An ammonia molecule (NH_3) has a permanent electric dipole moment 5.0 * 10^-30 Cm . A proton is 2.50 nm from the molecule in the plane that bisects the dipole.
What is the electric force of the molecule on the proton?
E_dipole = K 2p / r^3 (on axis of electric dipole)
E_dipole = -K p / r^3 (in the plane perpendicular to an electric dipole)
E_dipole = (F on q) / q
p = 5.0E-30 Cm
r = 2.50E-19 m
Use second equation because the question implies its perpendicular to the electric dipole of ammonia?
q of proton = q_p = 1.60E-19 C
F_(molecule on proton) = F = E_dipole * | q of proton |
F = [-K * (p / r^3)] * |q_p|
F = [(-9.00E9) * (5.0E-30) / (2.5E-9)^3)] * 1.60E-19
F = -4.60E-13 N
Help would be awesome!
The solution looks correct to me. The student should state the physical meaning of the negative sign of the answer.
