Which pair of elements is most apt to form an ionic compound
The discussion centers on which pair of elements, nitrogen and hydrogen or barium and bromine, is more likely to form an ionic compound. It is established that for a bond to be ionic, the difference in electronegativity must exceed 1.7. The electronegativity difference between nitrogen (3.0) and hydrogen (2.2) is less than 1.7, indicating a non-ionic bond, while the difference between barium (0.89) and bromine (2.96) exceeds 1.7, suggesting an ionic bond. Additionally, the concept of polarization is introduced, where a high charge density cation can distort an anion's electron cloud, potentially leading to covalent bonding instead. Overall, while electronegativity is a key factor, other elements such as atomic size and polarization also influence bond formation.
p4cifico
which pair of elements is most apt to form an ionic compound with each other? nitrogen and hydrogen or barium and bromine?
please explain
Chemistry news on Phys.org
one way to look at it involves electronegativity. For a bond to be ionic, difference in electronegativity should be greater than 1.7
electronegativity of N is 3.0, and that of hydrogen is 2.2
the difference is less than 1.7
electronegativity of barium is 0.89 and that of bromine is 2.96
the difference is more than 1.7, hence ionic.
more logically, the bond will depend on polarisation. This occurs when a high charge density cation distorts the electron cloud of a large anion. When polarisation occurs, there is sharing of electrons instead of transfer of electrons, hence a covalent bond.
While only looking at electronegativity, other trends come into play as well.
Bromine is atomic number 35, and Barium is 4.
Hydrogen is 1, and Nitrogen is 7. The valence shells around the hydrogen and nitrogen are a lot lesser. Hydrogen bonding is a very strong force. Despite the electronegativities, I believe that the Hydrogen and Nitrogen will be more apt to for an ionic compound.
(Don't count on me though, I'm only 16 and recently started AP Chem.
hydrogen bonding is an INTERMOLECULAR FORCE (even if we call it H-bond), it occurs between molecules, such as water or ammonia. it is in no way an actual bond.
actually electronegativity sums the atomic size. The fatter the atom, the smaller is the electronegativity and vice versa.
very good answers thank you everyone
