What are the possible directions for cross products involving three vectors?
The discussion focuses on determining the directions of cross products involving three vectors in a 3D space. The vectors are positioned at point P, with vector A pointing up, vector B east, and vector C south. Participants emphasize the importance of the right-hand rule for finding the direction of the cross products A x C, A x B, B x C, and B x A. Clarifications are made regarding the application of the right-hand rule, which is relevant for vector cross products as well as magnetic fields. The conversation highlights a common misunderstanding about using the left hand instead of the right hand for this rule.
Ryo124
Sketch a 3-dimensional picture showing the horizontal plane, a point P on the plane, a vertical line through P, and three vectors at P: vector A points vertically upward; vector B points toward the east; vector C points toward the south.
Now determine the cross product directions.
A x C
A x B
B x C
B x A
You have choices of: up, down, north, south, east, and west.
I don't know how to attempt to solve this. Someone please help.
Have you learned the right hand rule?
As I said, I have no idea on how to solve this problem.
I know the right hand rule, but I thought that it was only for currents, directions of B fields, and the direction of the magnetic force.
Someone please help if you can.
The right hand rule also applies to the cross product of vectors.
http://mathworld.wolfram.com/Right-HandRule.html
"The right-hand rule states that the orientation of the vectors' cross product is determined by placing u and v tail-to-tail, flattening the right hand, extending it in the direction of u , and then curling the fingers in the direction that the angle v makes with u . The thumb then points in the direction of u x v."
Thanks man. I was using my left hand... :blushing:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
