Free-Body Diagram Homework: Truck Accelerates at Red Light
  • Thread starter Thread starter CursedAntagonis
    Diagram
The discussion centers on a physics homework problem involving a free-body diagram for a truck accelerating with a box on its bed. The user correctly identifies the normal force acting upward and weight acting downward but struggles with the direction of the friction force and other components. They seek clarification on the correct representation of forces, particularly the friction force and the reaction forces involved. The user notes that their initial attempt at the diagram is incorrect and requests assistance in understanding the proper forces at play. The thread highlights the importance of accurately depicting forces in free-body diagrams for understanding motion.
CursedAntagonis
A large box containing your new computer sits on the bed of your pickup truck. You are stopped at a red light. The light turns green and you stomp on the gas and the truck accelerates. To your horror, the box starts to slide toward the back of the truck. (Assume that the truck is accelerating to the right.)
Draw clearly labeled free-body diagram for the truck. (The bed of the truck is not frictionless.)
N normal force
Wt Weight of the truck
fk is friction force of the box on the truck bed
Froad is the reaction force to the tires backward push
nb is the reaction to the normal force on the box from the truck
I got N going upward
Wt going downward
nb going downard
fk going to the right (forward)
Froad going to the right (forward)
However, it's not the correct answer. Anyone could explain to me what I got wrong here?
Thanks.
No one knows the answer or can lend me a hand with this?
Normal force of the box by the truck bed should be going up.
