Help with Optics Doubt: Sign Conventions in Problems
  • Thread starter Thread starter Nikhil_kumar
    Doubt Optics
In optics, sign conventions are essential for accurately applying formulas like the lens and mirror equations. During derivations, specific sign conventions are used to denote object and image positions, but these may differ in practical problems. When solving problems, the data provided can represent a different geometric situation, necessitating the application of sign conventions again to ensure correct calculations. This dual application helps clarify the relationship between the object and image in various contexts. Understanding this distinction is crucial for accurate problem-solving in optics.
Nikhil_kumar
.Please provide me with some help in optics. This doubt is in relation to the use of sign conventions in optics. Whenever we prove anything in optics, say for example, when we prove the mirror formula or the lens formula or the lens-maker's formula, we apply the sign conventions in the derivation of the proof itself (u=-ve, f=+ve or -ve etc., according to the New Cartesian Conventions). Then while solving problems based on these formulae, why do we again have to apply the sign conventions according to the data given in the question? I mean, to solve problems based on the lens formula , the mirror formula etc. why do we have to apply the conventions twice? After all the conventions have already been applied during the course of proof itself.
For eg, The lens formula: 1/f=1/v - 1/u is derived in case of real image by convex lens by putting u=-ve, f=+ve v=+ve during the course of proof itself.
Now while solving a problem based on this formula, why do we again have to apply the sign conventions according to the data given in the question? The sign conventions used in the proof of the lens formula are used to denote the positions of the object and image from the lens. That is, it is used to describe the geometry of the particular situation being considered. When solving problems based on the lens formula, the data given in the problem might include a different geometry than the one used in the proof of the lens formula. Therefore, the sign conventions must be applied according to the data given in the problem in order to correctly determine the positions of the object and image relative to the lens.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
