How Much Water Freezes at Equilibrium Temperature Tf=0?
  • Thread starter Thread starter coconut88
coconut88
Find the actual equilibrium temperature if Tf=0, how much of the water froze ?
helllllllllllllllllllllllllllllllllllllllllllllp me if you can
We need to see the complete question and your attempt first.
