Location of Ice Shield and Heat Shield in Relation to Fuel Lines on Boeing 777
  • Thread starter Thread starter samsam
    Heat Ice
The discussion focuses on the location of the ice shield and heat shield in relation to the fuel lines on a Boeing 777. Fuel tanks are located in the wings, with fuel lines running through the pylons to the engines. High bypass engines utilize the nacelle as a heat shield, providing insulation between the combustor and exhaust. The Boeing 777 can be equipped with either Rolls-Royce or GE90 engines, with specific models used in various incidents. The engines are purchased separately by airlines and installed by Boeing.
samsam
Where are the in relation to the fuel lines on a Boeing 777
Tanks are in the wing, and they must drop through the pylons (engine supports) to the engine. So the question would be where are the fuel lines in the engine, at least with respect to the combustor.
High by-pass engines have the bypass and engine nacelle to act as heat shields between combustor/turbine and exhaust.
This will give some idea of the inner workings of the engine.
http://www.geaviation.com/education/engines101/index.html
I think FredGarvin and others in the aerospace industry can provide better information.
Thanks for that, was it fitted with RR donks or GE90s?
The 777 has both RR and GE90. In the case of BA038, the engines were RR.
AFAIK, the airline or aircaft owner purchases the engines separately from the aircraft and they are shipped to Boeing where they are installed.
Cheers thankyou very much for your help Sir, i might need more.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
