VBA Macro Programming: Fix "Selection.Offset()" Problem
  • Thread starter Thread starter big man
    Programming
The discussion centers on a VBA programming issue involving the "Selection.Offset()" method, where users expect to retrieve a range but instead receive a single cell address. The original poster illustrates their problem with an example, stating that using "Selection.Offset(0, 1)" on a selected range results in only the address of the first cell in the new column, rather than the expected range. Further exploration reveals that when selecting a new end cell and applying the offset again, it still returns the address of the first cell instead of the expected end cell's offset. The conversation highlights the importance of understanding how the Offset method works and suggests that breaking the range into beginning and end points may help resolve the issue.
big man
Hi
I just have a quick question about a VBA program I've been writing. It's mostly working, but there is a slight problem when I use the "Selection.Offset" capability. For example, if I had a range selected of $C$23:$C$34 then I would have thought that if I did "MsgBox Selection.Offset(0, 1).Address" I would get a new range of $D$23:$D$34. However, what I get is actually D23 and that's all. There essentially isn't any range anymore. I've attached the section of code for you to look at so that maybe it makes more sense, but hopefully you have an idea as to why this isn't bloody working. I have to warn you though that I am a messy coder and so it isn't the most elegant work.
For Counter = 1 To NumberofColumns
If Counter = NumberofColumns - 3 Or Counter = NumberofColumns - 2 Or Counter = NumberofColumns - 1 Then
GoTo 124
End If
If AccessNoLoc - Counter = 0 Then
GoTo 124 'GOTO "Next Counter" in this loop
ElseIf AccessNoLoc - Counter < 0 Then
GoTo 115 'GOTO "Index = Counter - AccessNoLoc"
Else
For n = 1 To Rangarrsize
SelRange = Beginning(n) & ":" & Final(n)
Range(SelRange).Select
MsgBox Selection.Offset(0, -Counter).Address
With Selection
.MergeCells = True
End With
Next n
End If
115 Index = Counter - AccessNoLoc
If Index > 0 Then
MsgBox Selection.Offset(0, Index).Address
With Selection
.MergeCells = True
End With
Next n
End If
124 Next Counter
Appreciate any assistance!
Technology news on Phys.org
This is from John Walkenbach's web site. He's the guru on this:
http://www.j-walk.com/ss/
The Offset method is another useful way to refer to ranges. The Offset method returns a Range object, and takes two arguments. The first argument represents the number of rows to offset; the second represents the number of columns to offset.
The following statement assigns the value 1 to the cell that is one row below cell C2 and two cells to the right of C2 (i.e., cell E3):
Range("C2").Offset(1,2).Value = 1
The Offset method is most useful when the arguments are variables, rather than numbers. The subroutine below fills a 10X10 range (rowwise) with consecutive numbers from 1 to 100.
Code:
Sub FillRange2()
      Num = 1
      For Row = 0 To 9
          For Col = 0 To 9
              Sheets("Sheet1").Range("A1").Offset(Row,Col).Value = Num
              Num = Num + 1
          Next Col
      Next Row
End Sub
I think with a little stroking you can make this fir your needs.
Thanks for that Fred. I've modified it now so that I've broken the "range" up into a beginning point and end point and so now I offset each part.
So as you can see by the code below I have a beginning cell (beg) and an end cell (fin).
Now when I put a MsgBox to print both of these cell addresses I get say D1 for beg and D3 for fin. Then when I do Range(Beg).Select and I offset the Beg cell by 1 column using Selection.Offset(0,1).* and I print the address I get E1. However, the problem arises in the next line when I do a new selection. The new selection is selecting the end cell. But when I print the offset for this selection I again get E1 instead of getting E3. Is there something I'm missing?
Beg = Beginning(n)
Fin = Final(n)
Range(Beg).Select
def = Selection.Offset(0, 1).Address
MsgBox def
Range(Fin).Select
abc = Selection.Offset(0, 1).Address
MsgBox abc
Next n
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
