Kinetic energy of a particle help
The discussion revolves around calculating the kinetic energy and speed of a particle as it moves between two points. The particle has a mass of 0.600 kg and a speed of 2.30 m/s at point A, leading to a calculated kinetic energy of 1.59 J at that point. At point B, the kinetic energy is given as 7.00 J, which results in a speed of approximately 4.83 m/s. The total work done on the particle during its movement from A to B is calculated to be 5.41 J. The conversation highlights the use of the kinetic energy formula and the work-energy principle in solving the problem.
Sheneron
A 0.600 kg particle has a speed of 2.30 m/s at point A and kinetic energy of 7.00 J at point B.
(a) What is its kinetic energy at A?
(b) What is its speed at B?
(c) What is the total work done on the particle as it moves from A to B?
J= N*m
I am stuck on this problem and don't really know how to go about starting it. I think if i new the first part I could find the other two answers, but I don't know how to do that. Any advice would be appreciated.
What is the formula for kinetic energy?
k=.5mv^2
so, k=.5(.6)(2.3^2); k=1.59
b) 7=.5(.6)v^2; v=23.3333^.5; v=4.83
c) (sum)W= kf - ki ; (sum)W= 7-1.59 = 5.41
Thanks,
its been a long day sorry
heh. no problem. It looks like you know EXACTLY what you are doing! =)
