What is the Correct Solution to 92x^3y divided by -28xy^3 in Algebra?
The problem involves simplifying the expression 92x^3y divided by -28xy^3. The correct simplification yields 23x^2 divided by -7y^2. A common point of confusion is the handling of the negative sign, which can be placed in front of the numerator. The discussion emphasizes that -1/2 is equivalent to 1/-2, reinforcing the importance of consistent sign placement. Understanding these simplification rules is crucial for accurate algebraic manipulation.
Enos
I got 23x^2 divided by -7y^2
book inverted the negative. What did I do wrong?
