How Does Temperature Affect Tire Pressure?
  • Thread starter Thread starter zcabral
    Pressure
Temperature significantly affects tire pressure, as demonstrated by a scenario where air in a tire is compressed to 26% of its original volume while the temperature rises from 10.0°C to 32.0°C. The relevant equation used is p1V1/t1 = p2V2/t2, which requires temperatures to be in Kelvin. After calculations, the final tire pressure is estimated to be around 4.1 atm or 420 kPa. The discussion highlights the importance of considering both volume reduction and temperature changes when determining tire pressure. Accurate conversions and significant figures are essential for precise results.
zcabral
An automobile tire is inflated with air originally at 10.0°C and normal atmospheric pressure. During the process, the air is compressed to 26.0% of its original volume and the temperature is increased to 32.0°C.
(a) What is the tire pressure?
p1V1/t1=p2v2/t2
i know this is simple but I am just not getting the right answer I keep using p1V1/t1=p2v2/t2 but wrong answers come out. i used 1 atm for normal atmospheric pressure
Remember that T must be in Kelvin since you are dividing by it.
yes it is in kelvin...i got 419903.5 is that right?
First estimate the answer!
Temperature hasn't changed much in absolute terms
volume has gone down by a factor of 4 - so we want a pressure of around 4 atm.
V1 = 1
V2 = 0.26
P1 = 1atm
T1 = 283K
P2 = ?
T2 = 305K
1/283 = 0.26 P /305
So P = (305 /283) / 0.26 = 4.1 atm or around 420KPa
ps. That's an impressive number of significant figures given the data!
it asks for it in pa that's y
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
