Estimating Pressure, RMS Speed of Hydrogen in Space
  • Thread starter Thread starter fredrick08
    Hydrogen Space
The discussion centers on estimating the pressure and rms speed of hydrogen atoms in space, where the number density is approximately 1 atom/cm³ and the temperature is 3 K. The pressure is calculated using the ideal gas law, resulting in a value around 4.14 x 10^-17 Pa. The rms speed of the hydrogen atoms is derived from the kinetic theory of gases, yielding a speed of approximately 273 m/s after correcting earlier miscalculations. Participants emphasize the importance of using correct constants and formulas, particularly in transitioning from atomic to molecular considerations. Overall, the thread highlights the challenges of applying thermodynamic principles to low-density gases in space.
fredrick08
in space far from stars is filled with a very low density of hydrogen atoms, the number density is about 1atom/cm^3 and T is about 3degreeK
a. estimate the pressure in space, answer in Pa and atm.
b. what is the rms speed of the atoms
c. what is the edge length L of an LxLxL cube of gas with 1J of thermal energy
k=1.38x106-23
1atm=101.3kPa
atomic mass of hydrogen=1.67x10^-27kg
N/V=n
vrms=sqrt(3kT/m)
N/V*M=m
PV=NkT
a. P=(N/V)kT=(1/1x10-6)*1.38x10^-23*3=4.14x10^-17Pa=4x10^-22atm?
b.m=(N/V)M=(1/1x10^-6)1.67x10^-27=1.67x10^-22kg
so vrms=sqrt(9*1.38x10^-23/1.67x10^-22)=.86m/s?
and c. i have no idea, please someone help, this micro macro stuff is stupid... I am not sure about the vrms formula is correct, since in the book it says its for molecules, but i can't find anything on atoms... I am pretty sure i have done something wrong for the number density, as i don't know, coz its in atoms/cm^3... and I am just stuck please some help me...
ok well i think m is just atomic mass so vrms=sqrt(9*1.38x106-23/1.67x10^-27)=273m/s i think
please can anyone tell me if i am doing this right?
Hi fredrick08,
What is the average kinetic energy of one atom? And so how many atoms would you need to give 1 J of energy? Once you have that, how is the number of atoms related to the volume they occupy?
How about just converting to moles per volume? A gas is 22.4 liters per mole at STP. Just use the gas laws from chemistry.
Hi sirzerp,
Perhaps I'm not understanding your train of thought; how will converting to moles and calculating volumes at STP help find the volume containing 1 J of energy at 3K?
(a) looks good to me
(b)
Right idea, but one of the numbers is incorrect here.
alphysicist said:
Hi sirzerp,
We know the number of moles per volume and temp. Just treat it as an ideal gas right?
Once you know pressure, is not pressure a direct energy unit?
Hi Redbelly98,
(b)
There is a 6 where a ^ should be; but I think other than that the numbers are correct. Are you seeing something that I am overlooking?
Yes, so you could use
<br /> P =\frac{2}{3}\frac{U}{V}<br />
and solve for V; but I don't think you need to convert to moles or calculate things at STP.
My original suggestion also gave the volume in two step from the given data. The number of molecules giving an energy U is:
<br /> U=\frac{3}{2} N k T<br />
and since the density is (1 atom/cm^3) then number for N is the volume (in cm^3).
Oops, I was looking at the first factor of 9, thinking it should be a 3. But he had already multiplied 3 with the T=3K.
Sorry! :redface:
(b) looks good to me now!
ok ty heaps, srry i was away, just got up lol, ok it makes sense now, srry for also confusing anyone, unfortunately I've never done chemistry before, so i don't really know the chem formulas just the ones in my physics book...
