Why Does the Cosine of Angle OAB Calculate to Negative Two Thirds?
  • Thread starter Thread starter nokia8650
    Cosine
nokia8650
Relative to a fixed origin O, the point A has position vector 4i + 8j – k, and the point B has position vector 7i + 14j + 5k.
(a) Find the vector A to B.
(b) Calculate the cosine of OAB.
(c) Show that, for all values of t, the point P with position vector ti + 2tj + (2t - 9)k
lies on the line through A and B.
I am having problem with parts b and c.
For a) - A to B is (3i + 6j + 6k)
for b), I get the cosine of the angle using the dot product formula to be positive 2/3 - however the markscheme says negative 2/3.
I am really stumped with c - I don't know how to tackle this problem. I can find the equation of the line AB to be r= (4i + 8j - k) + t(i + 2j + 2k). However, I don't understand how this ties into the question. I can see that the "t" coefficients are the same, but where does the -9 in the question come from?
Thanks
For computing the angle OAB I think they want you to find the vectors relative to the origin A (i.e. two arrows going outward from A). One is the AB that you found, but the vector from A to O is actually -A. For c) there are lots of different ways of writing the parametric equation of corresponding to changes in the parameter t. You line equation is (t+4)i+(2t+8)j+(2t-1)k. Try substituting t->t-4. Same line, different equation.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
