Building a DC to DC voltage regulator
To regulate 12 volts DC from a car battery down to 1.24 volts DC while drawing 12-15 amps, a buck converter is recommended. The discussion highlights the need for adjustable voltage output and suggests using a 20A buck regulator chip from National Semiconductor. Participants are encouraged to share additional component recommendations and circuit designs. The focus remains on achieving efficient voltage regulation for high current applications. Assistance is sought for practical implementation and component selection.
dancingbear
Could anybody please assist me.
I need to regulate 12 volts dc from a car battery down to 1.24 volts dc yet I still need to be able to draw 12 - 15 amps. Ideally I would like to be able to adjust the voltage. Does anybody have any ideas how I will be able to achieve this & if so, what components will I need?
Thanks
Thanks
Here's a 20A buck regulator chip and application info from National Semiconductor:
http://www.national.com/mpf/LM/LM2746.html
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
