xtempore
- 19
- 13
I tried to make a double-slit experiment, but I got some difficult-to-explain results.
I cut a piece of opaque plastic in two and then stuck it back together with a human hair (mine) stretched in between, thus forming a double slit.
I then mounted the "double slit" 1m from a sheet of white paper and shone a red laser pointer through. The resulting diffraction pattern was very clear and I counted 13 bright bands within 2cm of the middle.
So...
slit to screen distance, L = 1m.
distance between maxima, x = 2cm/13 = 1.5mm = 0.0015m
separation of slits (diameter of hair - estimate), d = 90microns = 0.00009m
using lambda = x.d/L gives
lambda = 1.35e-7m = 135nm - HUH?
Red light is around 620-750nm. L = 1m is right, and I'm pretty sure about there being 13 bright bands in 2cm. The remaining variable is the hair width, but for the numbers to match up would require a width of around 450microns - way thicker than any human hair.
So what gives? Any ideas are welcome.
In the meantime I might try some variations on the setup to try and get some clue as to where it went wrong.
X
So...
X
