Calculating Stress Tensor and Voltage for MEMS Project
leofur
Hi all,
I'm doing a MEMS project, I have a cantilever beam with a mass at its end, I need to calculate the stress tensor at the beam contact point, there is a piezoelectric matirial there, and I want to calculate the voltage it generates. somebody can please help me and explain how to calculate the stress tensor there, I don't know solid state physics that good, and the last 2 days I was searching the web for this, but couldn't find anything.
leofur,
Not to pull hairs, but stress isn't a vector (first rank tensor) quantity. It is a second-rank tensor. Let me try to put the picture together. You have a piezoelectric material, which is actuating a cantilever beam and you want to calculate the stress at the beam/piezoelectric material contact point when a mass is loaded to the cantilever. Is that correct? Or is the beam being used to generate an electric field within piezoelectric material? Be very careful in how you phrase questions and don't be afraid to write a lot of detail.
Either way, the stress tensor in a cantilever beam will vary with distance from the neutral axis of bending. The stress in your piezoelectric material will depend where is situated with reference to the beam's neutral axis. The voltage generated in a piezoelectric material is proportional to the stress state. There must be some constitutive relationship in a textbook. Or look up the ginzburg-landau theory for piezoelectric phase transformations. This theory is the basis for developing a constitutive relationship between stress and electric field.
modey3
leofur said:
Hi all,
Well, if you know the cantiliever geometry and boundary conditions (built-in cantilever, for example), you can calculate the deformation (or approximate it fairly easily), and from the material properties, the local stress. Plug that into the appropriate piezo-electric coefficient, and you are done.
Can you more simply empirically determine the relationship- using a series of cantilevers, or masses, or...?
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
