Does Changing Velocity Direction Affect Acceleration and Speed?
  • Thread starter Thread starter BeckyStar678
    Velocity
The discussion focuses on the relationship between velocity changes, acceleration, and speed in a cart's motion along a track. In scenarios where the original velocity is positive and the change is also positive, the cart speeds up with positive acceleration. Conversely, when the original velocity is negative and the change is positive, the cart also speeds up, but the acceleration is negative. If the original velocity is positive and the change is negative, the cart slows down, resulting in negative acceleration, while a negative original velocity with a negative change leads to a decrease in speed and positive acceleration. The key takeaway is that the direction of velocity change determines the acceleration's sign, emphasizing the importance of understanding motion direction.
BeckyStar678
a cart is pushed along a straight horizontal track
a.) in a certain section of its motion, its original velocity is +3 m/s and it undergoes a change in velocity of +4 m/s. does it speed up or slow down in this section of motion? is its acceleration positive or negative?
b.) in a certain section of its motion, its original velocity is -3 m/s and it undergoes a change in velocity of +4 m/s. does it speed up or slow down in this section of motion? is its acceleration positive or negative?
c.)in a certain section of its motion, its original velocity is +3 m/s and it undergoes a change in velocity of -4 m/s. does it speed up or slow down in this section of motion? is its acceleration positive or negative?
d.) in a certain section of its motion, its original velocity is -3 m/s and it undergoes a change in velocity of -4 m/s. does it speed up or slow down in this section of motion? is its acceleration positive or negative?
a.) it increases and acceleration is +
b.) it decreases and acceleration -
c.) it decreases and acceleration is -
d.) it increases and acceleration is +
Put the velocities out on a number line. Negative to positive, left to right.
Any change when you go from initial to final that is left to right is positive change. To the right is negative change.
Look at your problem again.
okay, so by looking at it again i got
b.) it increases and acceleration -
d.) it decreases and acceleration is +
i changed the accelerations because isn't it that when the signs are the same, that means that acceleration is + and when the signs are different the acc. is -?
It's the direction of the change in velocities. If velocity decreases, then acceleration is in the "decreasing" direction - i.e."-" - whether or not the signs of velocity are positive or negative. It's whether the differences are + or -.
Like housing values are determined by Location. Location. Location.
Here it's Direction. Direction. Direction.
