How Do You Calculate the Time for an Arrow to Return to the Same Height?
  • Thread starter Thread starter krausr79
    Initial
To determine how long it takes for an arrow to return to a height of 35 meters after being shot into the air, the initial velocity (Vo) must be calculated using the equation of motion. Given that the arrow reaches 35m in 3 seconds, the initial velocity was found to be 26.36 m/s. However, using this value in the quadratic equation yields two times: 3 seconds and 2.38 seconds, indicating a misunderstanding of the problem. The discussion suggests that there may be a need to reassess the initial velocity calculation, as one participant claims it should be 55.77 m/s instead. The key takeaway is that the correct initial velocity is crucial for accurately determining the time of ascent and descent.
krausr79
I am given a height and a time it took to get there under 'free fall' conditions. 35m after 3sec An arrow is shot into the air and is 35m high after 3 sec. How long until it returns (falls to) to 35m high again?
X=Xo+Vo*T+1/2*A*T^2
X = 35m
Xo = 0m
V = ?
Vo = To find
A = -9.8 m/s2
t = 3 sec
35=0+3*Vo+1/2*-9.8*3^2
solved, Vo = 26.36
Then, with time as a variable:
35=0+26.36*t+1/2*-9.8*t^2
0=-35+26.36*t-4.9*t^2
Using the quadratic formula gives me 3 seconds and 2.38 seconds, but that means it assumed that 3 seconds was the return time and 2.38 seconds was when the arrow first arrived. 3 seconds was meant to be the first arrival. There must be a second initial velocity that causes 3 seconds to be the first arrival, but the equation doesn't suggest any way to find it. How is that possible? What is the real initial velocity?
There is only one possible initial velocity, since the equation of motion is linear in v_0. I calculated 55.77m/s where you got 26.36m/s. Check your working.
