How Does the Right-Hand Rule Determine EMF Direction in a Non-Conducting Loop?
The discussion focuses on determining the direction of induced electromotive force (emf) in a non-conducting loop adjacent to a straight wire carrying an increasing current to the left. Participants emphasize the importance of analyzing the magnetic field produced by the wire, which influences the loop. Applying Lenz's law is crucial for identifying the direction of the induced emf based on the changing magnetic field. The outcome depends on the specific configuration of the setup, particularly how the magnetic field interacts with the loop. Understanding these principles is essential for accurately predicting the behavior of the system.
Kathi201
A long, straight wire is in the same plane as a wooden, non-conducting loop. The wire carries an increasing current I in the direction shown in the figure (the current is pointing in the left direction).
a. there will be no induced emf and no induced current
b. there will be a counterclockwise induced emf, but no induced current
c. there will be a clockwise induced emf, but no induced current
d. there will be a clockwise induced current in the loop
e. there will be a counterclockwise induced current in the loop
How do you figure out the direction of the emf if you know the direction of the current. The direction of the current is to the left so I believe that means it is moving clockwise. Does that mean that the emf is moving clockwise as well?
The answer here will depend on how the figure is drawn. As a first step, think about the B field prodeced by the wire. Which way is that B field passing through the loop? Once you have that, you can apply Lenz's law to find the direction of the induced emf.
