What Is the Radius of the n = 6 Bohr Orbit in O7+?
  • Thread starter Thread starter rayfieca
    Radius
To calculate the radius of the n = 6 Bohr orbit in O7+, the relevant formula must account for the nuclear charge, which is Z=8 for oxygen. The standard equation r(n) = (n^2) * a(b) applies to hydrogen-like atoms but needs modification for different atomic numbers. The correct radius for the n = 6 orbit in O7+ is 238 pm, which requires using the adjusted formula that incorporates the atomic number. Users are encouraged to consult resources on "hydrogen-like" ions for a clearer understanding. Accurate calculations depend on recognizing the influence of nuclear charge on the orbit radius.
rayfieca
Calculate the radius of the n = 6 Bohr orbit in O7+(oxygen with 7 of its 8 electrons removed).
A) 190 pm B) 167 pm C) 238 pm D) 214 pm
I believe that the relevant equation is
r(sub n)=(n^2)*a(sub b) where a(sub b)= Bohr's radius= 5.29*10^-11 m
I calculated it for what I believed to be n=6, but I got an incorrect answer. The correct answer is (C) 238 pm, but I do not understand why.
Any help is greatly appreciated!
Your formula is not quite complete. You need to take into account the charge in the nucleus (so the number of protons).
Welcome to PF :smile:
Your equation is for hydrogen, with a charge of +1 on the nucleus.
Since oxygen has a charge of Z=8 for the nucleus, that equation should be different, containing Z somehow.
Does your textbook discuss "hydrogen-like" or "hydrogenic" ions?
EDIT: ah, I should know better than to wait a 1/2 hour and then respond without refreshing the page. :redface:
Unfortunately,
I cannot find an equation that takes into account (Z). Anyone have the equation handy?
Thanks for all your help!
Thank you very much!
