What type of motor for an electric scooter?
For building a battery-powered electric scooter, a DC motor is recommended due to its compatibility with battery power and simplicity. Lithium-ion batteries are suggested for their high energy density, providing longer range. It's important to consider the motor's power output and gearing to optimize for torque or speed. A regenerative braking system can enhance efficiency by recharging the batteries during use. The design process should prioritize selecting the best battery first, followed by finding a suitable motor.
A.Haba
What type of motor for an electric scooter!?
Im trying to build an electric scooter for my physics for engineers class.
I'm having trouble decidin on using AC or DC motors
it needs to be battery powered.
does anyone have advice?
Batteries provide DC power so it would seem reasonable to select a DC motor to keep complexity and cost down.
CS
I agree, DC motor is probably the simplest option in this case. As for sizing it, download this application from MAXON motors, pretty cool:
http://www.maxonmotor.com/downloads.asp
You could probably buy and entire system from them, although it will cost you;) But at least you should get an idea of what size of motor and gearbox you need. For power go for lithium-ion batteries which have a very high energy density, so longest range for your scooter.
If you are good in power electronics, you can make a re-gen braking system to charge your batteries back up instead of wasting all your kinetic energy as heat;)
Agreed... DC is the way to go. You would waste a huge amount of energy if you ran your batteries through an inverter to get AC. I have a few 12VDC motors from wheelchairs that put out 1/2 HP. That should be plenty for a scooter, and remember that you can alter your gearing for max torque or speed.
There are a lot of motors out there. One for almost any application. Personal electric transportation gadgets tend to be limited by available storage capacity, not the motor.
Since your ability to take power with you wil define the range, and usefulness of the thing you should start your design pocess with the battery. When you've found the best battery you can get, then go looking for a motor that's stout enough to take you down the road.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
