Hydrolics, Forces and flow rate.
The discussion focuses on calculating the forces involved in raising a traffic barrier using hydraulics. The motor specifications include a speed of 1400 rpm and a torque of 200 Nm, while the lobe pump delivers 1.5 l/min of hydraulic oil through a 50mm² hose to a piston of 1320mm². The original poster seeks guidance on determining the force exerted by the pump/motor on the fluid, specifically using mass flow rate. Clarifications reveal that the barrier in question is a parking barrier, not a railway arm, and that there is no counterbalance involved. Additional formulas and resources are shared to assist in the calculations.
GuitarWill88
Hi, I'm currently trying to work out the forces involved in raising a traffic barrier.
It works using hydrolics.
It has a motor that has a speed of 1400 rpm and 1/3 hp. the torque of the motor is 200Nm
the pump is a lobe pump and has a delivery of 1.5 l/min.
The pump will move the hydrolic oil through a hose 50mm2 and then into a piston of 1320mm2
I need to work out the force that the pump/ motor is exerting on the fluid. However i am not sure how i can do this only using the mass flow rate.
If anyone can tell me if this can be done/ how to do it would be great. If there is any additional information needed to solve this problem i can probably provide it.,
Thank, Will.
By traffic barrier do you mean one of those arms that drop down by railway lines? They have a counterweight opposite the arm that basically cancels the weight of arm so you don’t have to lift very much. For the hydraulics you must decide how fast you want it to operate as well as the force needed. Here are some formulas to get you started:
http://www.hydraulic-systems.com/pages/ref_formulas.htm
Thanks, those formulas have been quite useful.
By parking barrier i meant the type of barrier use in car parks to let you in/ out. The are usually powered using an electric motor or a hydrolic pump. The is no counter balance
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
