Atwood Machine Related Question
To determine the force the window-washer must exert on the rope to accelerate himself and the platform at 0.84 m/s², the relationship between the forces and tension in the rope must be understood. The discussion clarifies that the tension in the rope is effectively halved due to the pulley system, meaning the force exerted by the washer is not a direct 1:1 ratio with the net force acting on him and the platform. When moving at a constant speed of 2.3 m/s, the force he exerts on the rope equals the weight of both himself and the platform, as acceleration is zero. The free body diagram should reflect two upward tension forces acting on the platform and the washer, reinforcing that T1 equals T2. Understanding these dynamics is crucial for accurately solving the problem.
Jimmy25
A 59-kg window-washer stands on a 17-kg platform. The platform is fixed to a rope that passes over a pulley attached to the ceiling, which allows the window-washer to raise himself and the platform. (a) To accelerate himself and the platform at a rate of 0.84 m/s2, with what force must he pull on the rope? (b) When his velocity reaches 2.3 m/s, he pulls so he and the platform go up at a constant speed. What force is he exerting on the rope?
I thought since there was only one pulley the ratio of the force of the window washer pulling on the rope to the net force due to tension on him and the platform would be 1:1. Evidently this is not the case. Is the force applied by the washer on the rope halfed by the pulley. If so why is this the case?
Think of it this way:
The tension in the rope pulls upward on the platform and on the hands of the man pulling on the rope. So, the tension pulls upward at two points, meaning you only need half the force you would need if the rope only pulled at one point.
So what would my FBD look like in this case?
I have T1 pulling up on the platform and Fg pulling down on the platform.
Now, what I had before was Fa pulling down on the other side of the pulley and T2 acting upwards canceling with T1. But this is not correct.
Could you explain how the forces would look on the other side of the pulley?
In your free body diagram, you have the rope pulling upward at two points, on the platform and the man.
This means that in your free body diagram, you will have two forces pulling upward, T_1 and T_2 with T_1=T_2.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
