What is the tension in a swinging vine with a given mass and velocity?
  • Thread starter Thread starter stressedout09
    Circular
The discussion focuses on calculating the tension in a vine when Jill, who weighs 61 kg, swings at a speed of 2.6 m/s. The relevant equation for tension in circular motion is F=mv^2/r, which accounts for both centripetal force and gravitational weight. Participants express confusion about setting up the equation and understanding the components of tension when Jill is both hanging and moving. Clarification is provided that total tension is the sum of tension from centripetal force and the weight of Jill. The conversation highlights the challenge of grasping circular motion concepts in physics.
stressedout09
Jill of the Jungle swings on a vine 6.6 m long. What is the tension in the vine if Jill, whose mass is 61 kg, is moving at 2.6 m/s when the vine is vertical?
F=mv^2/r
F=(61)(2.6^2)/6.6
When Jill is just hanging on a vine, what is the tension in the vine?
When Jill is moving with a velocity, what additional tension is added to the vine?
I'm sorry I still do not understand how to go about setting up the equation...I tried going over examples in my book for this type of circular motion but there does not seem to be any so I am beyond confused...I know that once I figure it out I will feel completely stupid but for now, I am just stumped. -_-
Total tension = tension due to centripetal force + tension due to weight.
thank you SOOOO much...i'm such an idiot! -_-
