What is the maximum base current for a BJT NPN transistor and how can I find it?
The maximum base current for a BJT NPN transistor is influenced by its hfe, typically ranging from 1/100 to 1/10 of the collector current. High voltage levels on the base should be avoided, as BJTs generally do not tolerate voltages over a volt well. For applications requiring an input range of 3 to 30 volts and a 5-volt output, using a 7805 voltage regulator is recommended, as it efficiently converts higher voltages to a stable 5 volts. The 7805 can handle input voltages from 7 to 37 volts and provides up to 1 amp of output current when properly mounted. Data sheets for specific BJTs will provide the maximum base current specifications needed for design considerations.
atwork123
in BJT transistors how can I find the maximum base current?
Do we have maximum voltage limitation for base of transistor? consider a resistor between input and base of transistor.
I want to use a transistor that its input range is from 3 to 30 volts and its output is 5 volts. how can i do it with BJT NPN?
Hi atwork-
BJT npn's don't like high voltages (over a volt or so), but do like current. Depending on the hfe of the transistor, the base current can be anywhere from 1/100 to 1/10 of the collector current. A darlington transistor can also be used. What range of power supply voltages and output currents are you talking about?
Bob S
Are you looking for a 5 volt regulator?
The common one is the 7805. This accepts an input voltage in the range of 7 volts to 37 volts and gives a steady output of 5 volts. Maximum current if mounted on a heatsink is about 1 amp.
These are available quite cheaply at electronic stores or online.
It is easy to use. It just has 3 wires. Input, Ground and Output.
It contains transistors but is really an integrated circuit.
BJT transistor data can be found on Google and they always list the maximum base current.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
