Verifying Refraction of Coin in Water & Benzene
  • Thread starter Thread starter KBriggs
    Refraction
The discussion focuses on calculating the apparent depth of a coin submerged in water and benzene. The user calculated the apparent depth for an observer in benzene, finding it to be 1.128 meters at the benzene-water interface. They then treated the entire tank as filled with benzene, resulting in an apparent depth of 0.885 meters. Another participant confirmed the user's method and calculations as correct. The exercise demonstrates the principles of refraction and apparent depth in layered fluids.
KBriggs
Hey,
this is just an exercise in my textbook. I think I have the solution, but I would just like for someone to verify my answer.
A coin rests on the bottom of a tank of water 1m deep, with a 20cm layer of benzene on top of the water. n for water is 1.33, for benzene it is 1.5. Find the apparent depth of the coin views from normal incidence in air above the benzene.
What I did was I split it up - I assumed an observer in the benzene, and proved that the ratio of apparent depth to real depth was:
\frac{d'}{d} = \frac{n_b}{n_w}=>d' = 1.128m for an observer in benzene at the b-w interface looking down through water.
Then I treated the problem as though the whole tank was benzene and the object was at a depth 0f 0.2 + 1.128m. The analysis was the same, with the result of d'' = 0.885m.
Can someone verify these numbers for me?
Your method and answer look good to me.
