What is the difference between integral and fractional horsepower starters?
  • Thread starter Thread starter lavalin
    Motor Starter
Integral horsepower starters are designed for motors with a power rating of one horsepower or greater, while fractional horsepower starters are suitable for motors with less than one horsepower. The distinction is primarily based on the motor's power capacity, with integral starters handling higher loads. For a small single-phase motor like the one mentioned (.14kW), a fractional horsepower starter is appropriate. Understanding this difference is crucial for selecting the right starter for optimal performance and safety. Choosing the correct starter ensures efficient operation of the motor.
lavalin
Integral HP (horsepower) motors have more than one HP. Fractional HP motors have less than one HP.
Bob S
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
