Partial Fractional Decomposition to obtain an integral.
Perseverance
Find the exact values of A, B, and C in the following partial fraction decomposition.Then obtain the integral using those values.
1/(x^3-3x^2) = A/x + B/x^2 + C/(x-3)
I'm not sure at this point.
To make the denominator on the right equal to the left...
A(x^2)(x-3) + B(x)(x-3) + C(x)(x^2)
so...
1 = Ax^3 +Cx^3 -3Ax^2 +Bx^2 -3Bx
From cubic values..
A + C = 0 So A= -C
From squared values...
-3A + B = 0 So A = 1/3B which also means C = -1/3B
From x values..
-3B = 0.
Here is where I am at a loss. The x value equation cannot possibly be correct. It would denote that B=0, therefore A and C also equal 0. Am I doing something incorrectly in my multiplication? If not, how is it possible to use the partial fractional decomposition method to make an equation for integration?
you made the mistake here: 1=A(x)(x-3)+B(x-3)+C(x^{2})
Wow, this problem just became possible. Thank you so much :)
Actually, what implications does factoring out an x have on the numerical answers?
Edit: Never mind I understand how that was able to be done, it should have no implications. thanks again!
so...
Multiplying both sides of your first equation by x^2(x-3) gives
1= Ax(x-3)+ B(x-3)+ Cx^2
Taking x= 0 gives immediately 1= -3B and taking x= 3 gives immediately 1= 9C. Taking x= 1 (just because it is a simple number) gives 1= -2A- 2B+ C. Since you already know B and C, that is easy to solve for A.
From cubic values..
A + C = 0 So A= -C
From x values..
-3B = 0.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
