Toppling occurs when a block's center of mass is not directly above its contact area with a horizontal surface. If the center of gravity shifts to the side of the contact area, the block will begin to rotate and potentially fall over. Friction is not necessary for toppling to occur, as the block will topple due to gravitational torque acting on it. The discussion clarifies that the center of gravity must be above or to the side of the contact area for toppling to happen, not below it. Understanding these principles is crucial for analyzing stability in physical systems.
#1
Shahid0072
56
Please explain me the toppling giving example of a block on horizontal surface? Is friction necessary? What's its deal with center of gravity?
I'm not completely sure I understood the question completely, but here goes:
If the centre of mass of the block is not above the contact area between the block and the table, it will start to move (fall over completely if there is nothing else that stops it). This happens whether there is friction or not.
Torquil
#3
Shahid0072
56
But how can center of mass ever be below contact point..I mean contact point is at lowest point on the surface..When does a block topple?
#4
torquil
648
Ah, I meant that either the centre of gravity is "above the contact area", or to the side of it. Not under it :-) If it is to the side of the area of contact, then you can prove that it starts to rotate to the side by considering the torque of gravity upon the object, with respect to some appropriately chosen axis.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
i want to just test a linear generator with galvanometer , the magnet is N28 and the wire (Cu) is of 0.6mm thikness and 10m long , but galvanometer dont show anthing ,
The core is PLA material (3d printed)
The magnet size if 28mm * 10mm * 5mm
If the universe is fundamentally probabilistic, and all possible outcomes are realized in some branch of the multiverse, does that invalidate the concept of scientific inquiry? If knowledge is merely a description of one particular branch of reality, does it have any inherent value?
