Particle in Motion | Position at t = 2.70 s and t = 2.70 s + Δt | x = 6t^2
  • Thread starter Thread starter GlobalDuty
    Motion Particle
To find the position of a particle at t = 2.70 s, the equation x = 6t^2 is used, resulting in x = 6(2.70)^2. For part b, the position at t = 2.70 s + Δt requires calculating the change in position, represented as dx = 12tΔt. The final position is then expressed as xf = x + dx, incorporating the initial position and the change due to Δt. This approach allows for understanding the particle's motion over a small time increment.
GlobalDuty
The position of a particle moving along the x-axis varies in time according to the expression
x = 6t^2, where x is in meters and t is in seconds. Evaluate its position at the following times.
(a) t = 2.70 s
(b) t = 2.70 s + Δt
xf =
(Use Deltat for Δt.)
I understand that for part A, all i do is plug in (2.70) into 6(2.70)^2 to get the answer.
But what do i do for part b with that "Δt"?? and the answer for part b is supposed to be in symbolic format
dx = 12*t*dt
And xf = x + dx.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
