Confused about Grade 12 Physics Questions? Get Help Here!
The discussion revolves around confusion regarding grade 12 physics concepts, specifically related to acceleration and direction during motion. The first question involves a car changing direction from north to east while maintaining constant speed, with the correct answer being that the acceleration is directed towards the northeast. The second question addresses a car turning from west to south, where the acceleration is indeed directed towards the southeast, confirming the statement as true. The key takeaway is that in circular motion, acceleration always points towards the center of the circular path. Understanding these principles is crucial for mastering physics concepts at this level.
Callistal
I know I know. This question must be uber easy in the eyes of you genius'. But the truth is - I'm taking grade 12 physics when I practically failed grade 11(well, I got 51...I wasn't trying, I swear!) so getting some of the concepts can get very confusing...and frustrating! Nonetheless, I need your help my good physics ebuddies!
1) A car is traveling north when it enters a curve. It maintains a constant speed and leaves the curve traveling east. The direction of the car's acceleration is
a)south -east b)north-east c)east d)south e) the car does not accelerate
I'm pretty sure the answer to thsi question is north east, however, since I never recall answering this type of question, I want to make sure.
2) A car drives with constant speed around a corner. If it enters the corner traveling west and leaves traveling south, the acceleration through the turn is directed south-east.
True or False??
I think its true...but I am not sure! haha
Thanks a tun!
Hi Callistal, welcome to PF.
When ever a particle is moving in a circular orbit with uniform speed, the acceleration is always towards the center of the circle.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
