Can monoprotic acids produce a greater pH change than diprotic acids?
  • Thread starter Thread starter BogMonkey
    Acids Strength
Sulfuric acid is identified as a diprotic acid that does not fully dissociate in dilute solutions, such as a 0.01M concentration, where it exists in roughly equal parts as sulfate (SO42-) and hydrogen sulfate (HSO4-). The discussion raises the question of how a monoprotic acid, specifically trifluoromethanesulfonic acid, can induce a greater pH change compared to sulfuric acid. This prompts further inquiry into the dissociation behavior and strength of these acids, suggesting that the pH impact may not solely depend on the number of protons an acid can donate.
BogMonkey
Sulphuric acid is a diprotic acid that dissociates completely when dissolved in water. How does a monoprotic acid like trifluoromethanesulfonic acid produce a greater pH change than H2SO4?
Chemistry news on Phys.org
Sulfuric acid is a diprotic acid that DOESN'T dissociate completely in water. 0.01M solution is about 50/50 SO42- and HSO4-.
Does it?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
