Conversation of mechanical energy
The discussion revolves around a physics problem involving a 700 g block released from height h above a vertical spring with a spring constant of 400 N/m. The block compresses the spring by 19.0 cm, leading to calculations of work done by the block on the spring, which is found to be 7.22 J, and the work done by the spring on the block, which is -7.22 J. The height h is calculated to be 0.86 m, and the maximum compression of the spring when the block is released from a height of 2.00h is determined to be 0.26 m using the quadratic formula. The discussion emphasizes the importance of significant figures in the final answers.
gujubomber
A 700 g block is released from rest at height h(not) above a vertical spring with spring constant k= 400 N/m and negligible mass. The block sticks to the spring and momentarily stops after compressing the spring 19.0 cm. How much work is done (a) by the block on the spring and (b) by the spring on the block? (c) What is the value of h(not)? (d) If the block were released from height 2.00h(not) above the spring, what would be the maximum compression of the spring?
h(not)=h0
Work on block wb= -1/2 kx^2
h(not)=-x +1/2 kx^2/mg
to find x :kx^2 -2mgx - 4mgh(not) = 0
a. i used work on block and got 7.22J
b. would be opposit energy of work on block thus being -7.22J
c.used h(not) and got 0.86 m
then from finding x i used quadratic formul and got x=0.26 m
d. do not know how to find2.00h(not)
You seem to have answered problem d at the end of problem c. I think you need
3 significant digits in your answer.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
