Considerations for acceleration allowance in calculating engine power?
  • Thread starter Thread starter Carvinos
    Engine Power
Calculating engine power solely for maximum speed does not account for acceleration, which is crucial for performance. If the engine is sized only for a top speed of 50 km/h, there will be insufficient power for acceleration, leading to sluggish performance in that speed range. To estimate acceleration, one can use the formula that considers power losses and vehicle mass. Additionally, the maximum traction force is limited by the tire's friction coefficient, impacting the vehicle's ability to accelerate. Therefore, incorporating acceleration allowance is essential for a comprehensive understanding of engine performance.
Carvinos
hello!
i have calculated an engine power of a prototype car by calculating the power losses against road gradients, air drag and rolling resistance. i have calculated these losses for max. car speed,lets say 50 kmph. what i need to know is do i need to consider acceleration allowance even when i have calculated the power of an engine for max. speed??if yes, then why calculating acceleration allowance for an engine when car cannot accelerate beyond 50 kmph as all my calculations are based on maximum speed.
pleasez do reply, I am confused...
Capitalize "I" when you use it in sentences.
It would also help if you could state your question clearly and in 1 line preferably.
If you ever plan to stop then yes you should consider it (in the form of negative acceleration).
Think of it this way, if you size your engine power according to your max speed of 50 km/h, then it would mean you have no power left for acceleration at that speed (terminal velocity). So it would also mean that from, say, 45 to 50 km/h you will experience very little acceleration and it will take you forever to break that 5 km/h gap.
To get an approximation of the acceleration of your vehicle you can use the simple Pw - Pl = Fvavg = (ma) (vf + vo) / 2, where Pw is the power at your wheel, Pl is the power losses @ vavg, m is vehicle mass, vavg is the average speed of the vehicle during acceleration, vf and vo are final and initial speeds and a is the average acceleration from vo to vf.
Of course, the time taken to go from vo to vf will be approximately t = (vf - vo) / a. This will give an optimistic value, but it will give you a good idea.
Furthermore, no matter what is the engine power, the maximum traction force you can get is dependent of the friction coefficient of the tire. So Fmax = µmtg, where mt is the mass of the vehicle on the powered wheels, g = 9,81 m/s² and µ is the tire coeff of friction (tourism tire = 0.75-1.0, racing tire = 1.25-1.5, bicycle tire = 0.6-0.75 (that last one is a guess))
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
