Calculating Amperage of Voltaic Cells for Efficient Electrochemical Reactions
  • Thread starter Thread starter SlidemanD
    Amperage Cell
An AP Chemistry student conducted an experiment to reduce copper from waste copper oxide using a voltaic cell, employing zinc oxidation to facilitate copper reduction. They prepared copper nitrate from copper oxide and created a zinc nitrate solution for the anode. The student seeks to calculate the amperage of the cell when shorted to estimate the reaction completion time. However, a response highlights that calculating amperage is complex due to the slowest reaction step often being mass transport, which is influenced by electrolyte properties and cell geometry. A suggestion is made to use a multimeter for measurement instead. The student expresses curiosity about Computational Fluid Dynamics (CFD), which is relevant for understanding mass transport in electrochemistry but is noted as complex and less favored by chemists. The discussion concludes with the student inquiring about optimizing the salt bridge to increase amperage, considering that a shorter, wider bridge may enhance reaction speed.
SlidemanD
Hello all,
I am an AP Chemistry student currently studying electrochemistry. The other day, some friends of mine and I discovered some waste copper oxide laying around the lab. We thought, "Why not reduce all the copper out of this?", and so we set to work.
We got our experiment authorized by the teacher, and constructed a voltaic cell based on the reduction of copper through the oxidation of zinc. We used nitric acid to make a solution of copper nitrate from the copper oxide, and boiled it down to solid to remove excess HNO3 and dissolved it in distilled water. Zinc nitrate was prepared as the anode solution. A KCl salt bridge was constructed.
The cell itself works fine, but I have a question about the time this reaction will take to complete. The reaction should complete when all of the copper ions have reduced. There are 2 Faradays of charge transferred per mole, and 96500 Coulombs of charge in a Faraday. Since Amperes measure Coulombs per second, I need to know how many amps the cell draws when short circuiting to calculate how long the reaction should take to reach completion.
Now, the fundamental question facing me: How do I calculate the amperage a voltaic cell runs at when shorted out? I realize that I could just measure it with my handy-dandy multimeter, but I really would rather learn to calculate it, and thus gain a further understanding of electrochemistry. Any advice is much appreciated.
~SlidemanD~
Chemistry news on Phys.org
Your not going to be able to calculate this so easily. The maximum reaction rate of a global reaction is always limited by the slowest step. In most cases in electrochemistry, the slowest step is ion-migration or mass transport. Do determine your rate of mass transport you would need to take into account not only the properties of your electrolytes but also the geometry of your cell. In other words would basically need to conduct a full CFD simulation of your cell in order to estimate your limiting losses. This is not a easy thing to do. If I were you, I'd stick to the handy-dandy multimeter.
Hey, thanks for the reply.
I thought the rate determining step would relate to the actual oxidation or reduction reactions taking place at the electrodes, so calculation of shorted amperage would at least be feasible. But alas, the mass transfer over the salt bridge is logically much slower; meter it is!
Just me being insatiably curious, what is a CFD simulation? It sounds like something I should know about if I want a career in chemistry.
Thanks again,
SlidemanD
CFD stands for Computational Fluid Dynamics and also can refer to multiphysics problems such that involve chemical reactions, transfer of charge, etc. CFD tends to push the limits of mathematics, something chemists generally despise very much, so you usually won't ever see a chemist doing CFD work.
So since the object of this reaction is to plate out copper, increasing the amperage drawn by shorting the cell makes the reaction proceed more quickly. So how can I adjust my salt bridge to accomplish this? It seems that a bridge short in length with a wide diameter would be ideal. Is this correct?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
