How Long Does the Y Meson Last?
  • Thread starter Thread starter Kommandant
    Lifetime Particles
The Y Meson has a rest mass of 9.6 GeV/c² and a measured width of 51 keV, which are crucial for calculating its lifetime. The relationship between energy and mass is highlighted through the equation E=mc². Participants expressed uncertainty about how the measured width relates to the meson's lifetime, with some speculating a connection to electric fields. Additional resources, such as a link to HyperPhysics, were suggested for further understanding. The discussion emphasizes the need for clarity on the relationship between energy width and particle lifetime.
Kommandant
The Y Meson has a rest mass of 9.6 GeV/c2 and a measured width of (Delta)E= 51keV. What is its approximate lifetime (delta)t?
E=MC2
And.. who knows?
We came to the conclusion that 9.6 GeV/c2 was related to E=MC2.. and we pretty much had no idea with the measured width of (Delta)E= 51keV ( we thought it might be related to electric fields though).
(Note: Planck's Reduced constant = 1.055x10^-34 and 1 ev = 1.6x10^-19 J)
The question gives you that information
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
