Have You Explored Orifice Plate FlowMeters in Pipe Research?
The discussion centers on research related to orifice plate flow meters in pipes, with a request for journal recommendations. Participants suggest consulting ASME standards for orifice plate sizing and design, noting the availability of detailed guidelines in their catalog. A specific ASME publication is mentioned, although it comes with a high cost of $195. The conversation emphasizes the importance of referencing established standards before exploring academic journals. Overall, the need for reliable resources in orifice plate research is highlighted.
Maverk
Hello People,
I was just wondering if any of you done any similar investigation on the following topic. Basically, i currently doing a research on orifice plate in a pipe. It would be great if you guys know any journals that i can refer to.
There are at least ASME standards for orifice plate sizing and such. Before diving into any journals, perhaps try some standards. I'd also try API.
Alrite, thanks .. ill have a look on the catalog and see that if i be able to get a copy
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
