Path Equation for 2D weakly-anisotropic harmonic oscillator
The discussion revolves around finding the path equation for a 2D weakly-anisotropic harmonic oscillator defined by two angular frequencies, ω_x and ω_y, with ω_y slightly greater than ω_x. The user attempts to derive the relationship between x(t) and y(t) by substituting t(x) into y(t), resulting in a complex equation. They express difficulty in simplifying this equation and consider using double-angle trigonometric identities but remain uncertain about their application. The user seeks guidance on further manipulation of the equation to achieve a more recognizable form. The conversation highlights the mathematical challenges involved in solving the problem.
lightbearer88
\omega_{x} = \omega
\omega_{y} = \omega + \epsilon
where 0 < \epsilon<<\omega
Question: Find the path equation.
I started with the 2D equations:
x(t) = A_{x}cos(\omega_{x}t + \phi_{x})
y(t) = A_{y}cos(\omega_{y}t + \phi_{y})
by inverting x(t) to get t(x), I then substituted the result into y(t). The result is as below:
y(x) = A_{y}cos[(\omega_{x}/\omega_{y})cos^{-1}(x/A_{x}) - (\omega_{x}/\omega_{y})\phi_{x} + \phi_{y}]
I guess it becomes more of a mathematical problem. How do I simplify this equation, hopefully to find something familiar? An idea I had was to use double-angle trig formulas but I am not sure how it would help.
I personally think this is quite challenging. I have been thinking about it for days now. I tried all the trig identities I know off to manipulate the equation but I can't seem to get it. Unless I am missing something.
Thanks in advance.
PS: A^x is actually A(subscript)x and similarly, A^y is actually A(subscript)y. I don't know what is wrong with the formatting.
maybe I should define what the symbols are:
\omega_{x} is the angular frequency in the x-axis
\omega_{y} is the angular frequency in the y-axis
I'd try to substitute the \omega you have and then try to expand it by small parameter \epsilon...
