Calculate Flow Rate Thru 3.175mm Nozzle Tip
The discussion focuses on calculating the flow rate through a 3.175 mm nozzle tip connected to a 19 mm delivery tube, supplied by air at 70 psi. Using Bernoulli's equation, the final velocity was determined to be 2997 in/s, leading to a calculated flow rate of 36.6 in³/s. The calculations assumed zero velocity in the tank and discharge to ambient pressure. Additionally, it was noted that for a more accurate flow rate, head loss due to the nozzle and pipe bends should be considered. The conversation highlights the complexities of using imperial units in fluid dynamics calculations.
jman123456789
It's been a while since I've had to do these calculations..
I'm looking for the flow rate at the wall of a 3.175 mm nozzle tip. The diameter of the delivery leading up to it is 19 mm. This is a vertical assembly and the source of the air at 70 psi is a 1/4" outer diameter tube that is approximately 2.5" above the exit. There is about 120 cfh available maximum for this setup.
Anybody looking to take a shot at this, I'd be interested in seeing your solution..
You can loosely solve this quickly by Bernoulli's equation. The equation can be written as:
<br /> \frac{p}{\rho} + \frac{V^2}{2} + gz = \mbox{constant}<br />
So, having what you know, we can solve for the final velocity, and then with the area, get the flow rate.
<br /> \frac{70 \frac{lbf}{in^2}}{0.43 \frac{lbm}{in^3}} + 0.0 + (386.4 \frac{in}{s^2})(30 in) = \frac{V^2}{2}<br />
Note here that I have assumed that the velocity in the tank is zero, and that the jet is discharging to ambient pressure (0 gauge). We multiply everything out for:
<br /> 162\frac{lbf\,in}{lbm} + 11592\frac{in^2}{s^2} = \frac{V^2}{2}<br />
Note the messed up term all the way on the left. That is the cause of much frustration using imperial units. In order to correlate a pound-mass with a pound-force, we need to use the gravitational constant. Now, note that everything here I'm using the inches-pounds-second (IPS) system. We add the gravitational constant:
<br /> \left(162\frac{lbf\,in}{lbm}\right)\left(386.4 \frac{lbm\,in}{lbf\,s^2}\right) + 11592\frac{in^2}{s^2} = \frac{V^2}{2}<br />
We now have in2/s2 on both terms. We multiply and add through for:
<br /> 8981481\frac{in^2}{s^2} = \frac{V^2}{2}<br />
Which results in a velocity of 2997 in/s. Calculate the area, which should be pretty easy. I found the flow rate to be 36.6 in3/s.
Now, for a more accurate calculation, you'll want to calculate the head loss due to the nozzle and pipe bends and add it as an extra term in the equation above.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
